Engine power sucks, replaced MAF, didn't help - engine codes inside...
Old Nov 18, 2008 | 06:13 PM
kylebee's Avatar
Default Engine power sucks, replaced MAF, didn't help - engine codes inside...
I replaced my MAF thinking that it would solve the problem because I was getting "Bank 1 Too Lean" type codes - research on this forum indicated that it was usually due to a bad MAF. I also had to replace my Engine Coolant Temp sensor, which went fine (after I got the right part).
Well, after replacing the MAF and ECT, I still get the following codes:
P1136 - System too lean in bank 1
P1565 - Idle Speed Control Throttle Position lower limit not attained
P0116 - Engine Coolant Temp.Circ Range/Performance
I cleared them today and we'll see what comes back, but since I replaced the MAF, is it likely that the first two codes are due to a vacuum leak?
Thanks a bunch.
Old Nov 18, 2008 | 06:14 PM
Jc61990's Avatar
if i remember correctly a bad ICM will cause a bank 1 too lean i think. not sure some one else will have to back me up
Old Nov 18, 2008 | 06:24 PM
CRAZYHAWK's Avatar
Check for vacuum leaks.
Old Nov 18, 2008 | 06:30 PM
onepoint8tee's Avatar
+1 for a vac leak. A bad ICM will cause you to misfire like a **** and if anything you'd run rich from the unburt fuel.
Old Nov 18, 2008 | 06:40 PM
kylebee's Avatar
I've never had to check for vacuum leaks before - any idea how I could do this? Just get a small spray bottle, fill it with water, and spray it around various hoses?
Old Nov 18, 2008 | 06:41 PM
No just buy about 10 ft of vac line and replace all of them (the small braided ones.) Also check any L or S shaped hoses around the intake manifold carefuly.
Old Nov 18, 2008 | 06:52 PM
kylebee's Avatar
Cool. I have a Hanyes book, but I can't find any pictures or installation guides for the vacuum lines. Any links? Couldn't find anything after searching a few pages of Google results.
Old Nov 18, 2008 | 07:10 PM
Search here, there was a thread not long ago that showed where they all are. But all you really have to do is look under the hood. They are pretty obvious.
Old Nov 18, 2008 | 10:41 PM
punkrocker5817's Avatar
have you gone through and cleaned the connections on all the wiring?
Old Nov 18, 2008 | 11:26 PM
kylebee's Avatar
I searched the forum and couldn't find anything specific. I'm not the best with "obvious" repairs and like to have as much information as possible.
Thanks again.
All Pau
Aug 16, 2007 09:36 AM
02DolphinA4
Jan 4, 2007 12:35 AM
