buying a used A8
is there anything i should look out for when buying a used A8? what are the main differences between the 05,06 and 07 models? im looking to buy within those 3 year models but did one year have a ton of issues or anything? im an audi noob so help me out please.
Well the biggest difference is the 07+ model which has an FSI 4.2L instead of the standard 4.2L. The 07 also uses a timing chain instead of a timing belt so it doesn't need service. The other thing is, the older the model the older the software of the MMI. The 06+ model has a interactive display for the audible parking system and an updated sound system. The 05 is also very good but may need some MMI updates at a cost to you.
STAY AWAY FROM AN 04 A8! Its the first year and there are tons of problems with it, including engine changes.
The 05 and 06 are pretty much identical, the 06 has a little more features like that parking aid screen, as well as upgraded inteior options.
The updates are usually for MMI performance problems, like there are glitches in the system when scrolling pages and things like that. You will probably notice something annoying when using the MMI that you would think there would be an update for.......and there probably is. That kinda thing.
Stay away from 04's -- lots of worries (sorry guys with 04's but it's well known). None as I am aware for the 05's on up. In 06 the grill changes to that ovalish shaped version. If you like that, look for an 06 or newer. I wasn't aware of the new 4.2 engine in the 07's. I'll have to look at those closer.
s thinking about buying the allroad. What do u guys thinMy Uncle is thinking about buying an allroad
apg96
Jun 10, 2005 08:56 PM
