What do these fault codes mean ?
Old Sep 15, 2011 | 08:50 PM
JeePee's Avatar
Default What do these fault codes mean ?
Wednesday,14,September,2011,18:29:07:43475
VCDS Version: Release 10.6.4 (x64)
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Control Module Part Number: 8P0 907 279 P HW: 8P0 907 279 P
Component and/or Version: Bordnetz-SG H54 2903
Software Coding: 13AC2F81C0141380EF00001C00800000002A4E056406400300 1800000000
Work Shop Code: WSC 06314 000 08192
Additional Info: 8P1955119F Wischer AU350 H10 0040
VCID: 4A91756C5C2F
Fault Codes have been Erased
2 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 74882 km
Time Indication: 0
Date: 2011.09.13
Time: 18:28:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
OFF
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 74882 km
Time Indication: 0
Date: 2011.09.13
Time: 18:28:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
OFF
I cant figure out what it means ? Voltage too high or too low ?
This happend after a bi-xenon install over halogen. On a 2009 Audi A3 S-Line.
I cant figure out why my LEDS dont light up...
I plugged the Kufatec harness wire on the ECM on plug A pin 7 and plug D pin 10. Those are supposed to be the ' SIDELIGHTS' pins.
The LED DRL dont light up, so i guess there is no power going trought the wire...
09-Central Elextronix
Coding -> Function 07
Byte 00 Bit 1: Xenon Headlights installed
Byte 03 Bit 4: Xenon-Shutter installed (Bi-Xenon) Can't code this one, tell me 'Error 31'
Byte 17 Bit 1: Deactivation of Additional High Beam with Bi-Xenon
Byte 21 Bit 26: (26= BI-Xenon with DLR LED) change byte 21 from 25 to 26 This is a drop down menu, i chose option 6, Bi-xenon with LED DRL
I did this.
Old Sep 15, 2011 | 09:46 PM
etzbseder's Avatar
Did you remember to recode the computer so that it knows you have HIDs in instead of Halogens?
Old Sep 16, 2011 | 09:29 AM
JeePee's Avatar
VCID: 4A91756C5C2F
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 74882 km
Time Indication: 0
Date: 2011.09.13
Time: 18:28:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 74882 km
Time Indication: 0
Date: 2011.09.13
Time: 18:28:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
OFF
I did this.
Yes, i did recode them.
m.c.
May 2, 2012 01:40 PM
PandaXpress
Jul 25, 2009 10:47 AM
1Move
Dec 1, 2007 05:37 PM
mitao2000
Aug 30, 2006 11:53 AM
BaconBait
Aug 8, 2005 08:21 PM
