1997 A4 Front Wheel Bearings
Old Jul 27, 2007 | 08:12 AM
patrickm2002's Avatar
Default 1997 A4 Front Wheel Bearings
My mechanic just replaced buth my front wheel bearings about a few months ago. The car ran so much better for a few weeks after that, but started making the same noises again. Has anyone had the same issue where the bearing replacement didn't "take" the first time? Is this a common occurrence?
Old Jul 27, 2007 | 08:18 AM
micko's Avatar
Default RE: 1997 A4 Front Wheel Bearings
the mechanic who replaced your wheel bearings shouid have told you to come back after a month or so . and retightened them once they were bedded in this is pritty common with new bearings and only takes ten minutes or so to nip them back up
Old Jul 27, 2007 | 08:21 AM
I just took it back in this morning. He's going to look at it and may have to replace them AGAIN....
Old Jul 27, 2007 | 08:23 AM
micko's Avatar
hope theres no charge he shouid have told tou they wouid need nipping up
Old Jul 27, 2007 | 09:16 AM
I asked him about the bearings, he said if that was it, he would replace for free...
I just got off the phone with him... He tells me it's not the bearings. He thinks it might be the transmission? Would that have anything to do with it? The vibration is only coming from the passenger side front wheel?....
Old Jul 27, 2007 | 09:31 AM
micko's Avatar
get hold of the front while car is parked one hand on each side grip the back of the wheel with your fingers and pull and push if there is any movement or slackness the wheel bearing needs replacing cant understand why he has replaced the bearings if he knew they were not the problem sounds as thou he is making excuses to get out of not doing the job correctly ask him why they were not nipped up after a month or so
Old Aug 10, 2007 | 12:37 PM
Armenian's Avatar
hey guys i have a question i did my rear right wheel bearing the inner and outer one about a month and a half or so, what exactley is "nipped"?
Thanks
Tapeman
B8 Models
Oct 19, 2014 07:27 PM
Expplucky
Aug 16, 2013 03:20 PM
gotquattro
Jan 2, 2010 03:44 PM
fritz
Sep 5, 2007 07:08 PM
fhf3723
Mar 12, 2007 05:28 AM
