2000 a4 1.8tqm making a popping noise
Old Dec 14, 2006 | 03:20 AM
Robsa4's Avatar
Default 2000 a4 1.8tqm making a popping noise
what i take off of when i turn or stop the car makes what i think is a popping noise but it may be a grinding noise can someone help me with this and tell me what this is.
Old Dec 14, 2006 | 03:27 AM
tractioncontrol's Avatar
Default RE: 2000 a4 1.8tqm making a popping noise
Possibly lower control arms or bad ball joints. To test lower control arms with the vehicle on the ground try tightening the lug nuts on front wheels, if they are bad the whole wheel will move you will beable to feel the play. To test ball joint raise vehicle grab front lower part of tire (4 oclock) and try pushing and pulling slightly, play is obvious. Most likely control arms.
Old Dec 14, 2006 | 03:32 AM
Robsa4's Avatar
when testing the lower control arms does the car need to be raised up or on the ground and does the car need to be in gear or in neutral
Old Dec 14, 2006 | 04:03 AM
Robsa4's Avatar
if one of those it the problem is it urgent that i get it fixed or can i wait a little while before i get it fixed
Old Dec 14, 2006 | 04:24 AM
duburban's Avatar
where does the noise come from?
Old Dec 14, 2006 | 01:27 PM
JohnnyBravoA4's Avatar
the control arms are a known porblem i wouldnt let it go...
Old Dec 14, 2006 | 03:49 PM
Agro's Avatar
I agree control arms.
Possibly CV joints though?
I personally had a slightly bent front sway bar. I guess I ran something over? When the sway bar would turn it would tapping the subframe. Replacing the sway bar and the problem was resolved. Get your car on a lift, check out the movement of your suspension.
Tropski
May 14, 2013 10:51 PM
pbrules10
Feb 15, 2011 11:13 PM
dani3
Jul 11, 2010 06:23 PM
TurboQuattroPwr
Jun 2, 2006 08:03 PM
jstaco
Jun 26, 2005 11:06 AM
