AC air conditioner broken/doesn't work/wtf?
Old Jun 15, 2007 | 10:15 PM
csukoh78's Avatar
Default AC air conditioner broken/doesn't work/wtf?
I have an 03 A4. When I turn the AC on to any setting, even at 96 degrees outside, it blows HOT air. The only way I can get it to blow cold is to put it on LO and manually control the fan. Has this happened to anyone else?
No matter the temp outside, hot air unless on LO.
What could this be a malfunction of? What can I check?
Old Jun 15, 2007 | 10:59 PM
kovachian's Avatar
Member
Default RE: AC air conditioner broken/doesn't work/wtf?
By process of elimination, getting cold air on at least one setting shows that your compressor is ok and you have an adequate freon charge. If I had to guess I'd fault the climate control module. Only way to tell for sure of course is for a fault scan.
one4eyes
Apr 12, 2010 01:05 PM
duderseb
Sep 9, 2009 10:28 PM
DonStanleyA4
Dec 7, 2008 09:55 AM
Ezpanda
Oct 7, 2007 08:26 PM
Snabbast
Aug 13, 2007 06:02 PM
