air intake situation
Old Nov 27, 2006 | 07:06 PM
duhafnusa4's Avatar
Default air intake situation
hey,
I have a 1997 a4 2.8 12valve and im having a problem. i got a k&n cold air kit and then the check engine light came on. i got got it scanned and it said that it was because there was too much air coming in. the guy here said at first it was the maf so i replaced that, then he said it was the boost sensor. so i replaced that too. still not fixed he finally said it was because i didnt have the original airbox on it. im getting pretty mad because the money spent there was for performance upgrades. if anyone knows what i can do please help.
Old Nov 27, 2006 | 07:09 PM
acetrebo's Avatar
Default RE: air intake situation
What are the codes you are getting?
Old Nov 27, 2006 | 08:06 PM
duhafnusa4's Avatar
i dont remember, but it said boost flow(or something like flow) to high.
Old Nov 27, 2006 | 08:32 PM
acetrebo's Avatar
Well, it would help a lot if you could have the codes read again at autozone or somewhere.
A lot of times when people put in an aftermarket, oiled filter, the oil messes with the MAF.
Try cleaning the MAF sensor with some electrical cleaner or rubbing alcohol, it may help. and clear the code and see if it comes back. Just disconnect the neg. battery cable for 5 min. to reset ecu. It takes some driving for everything to reset, about 40 miles.
Old Nov 27, 2006 | 08:38 PM
wood_e's Avatar
+1 clean the MAF K&Ns are WAY over oiled from the factory.
Old Nov 27, 2006 | 08:40 PM
duhafnusa4's Avatar
i already cleaned the maf and the light still came on, ill get those codes again. i dont think the maf was the problem, when i took the stock airbox out there were some sensors i didnt know where to put, like an orange one with two plugins, there was nowhere for it so i zip tied it.
contacthansel
Oct 17, 2008 04:18 PM
LaueOfficer
Aug 13, 2007 01:28 AM
Karl
Oct 27, 2006 08:18 PM
Riemann
Jan 7, 2006 08:47 PM
