Blown fog light
Old Jan 27, 2008 | 11:34 PM
mrbear's Avatar
Default Blown fog light
Please help...
My passenger fog light on my 2001 A4 1.8T seems like it's blown out. Is this an easy fix? where can I order the bulb and how much should it cost?
I would appreciate any help at all.
Thanks,
Mr. Bear
Old Jan 27, 2008 | 11:53 PM
ImTheDevil's Avatar
Default RE: Blown fog light
The foglight is easy to remove. Pop out the grille next to the light, then pop off the bezel that's snapped onto the front of the light housing. Be careful - there are three tabs that snap it onto the light. Once those pieces are off, unbolt the fog, remove it, unplug it, and open it up to replace the bulb. The bulbs can be bought at any auto parts store, any WalMart, or about a hundred other places (including some gas stations even). Mine use an H7 bulb, and yours probably do too. Easy fix (10 minutes or so) and the bulb is about $6-8 depending on where you get it.
Old Jan 28, 2008 | 12:39 AM
cstarky15's Avatar
^^^^Like he said. it is really easy to do. you should just get two bulbs and replace the other one while you are doing it!
Munzter
Jul 17, 2013 05:53 PM
sntemp
Jul 6, 2010 07:44 AM
c2886s
Sep 28, 2007 12:18 AM
a4r6
Nov 15, 2006 02:34 AM
