Brake Indicator
Old Aug 26, 2005 | 02:09 AM
FezA4's Avatar
Default Brake Indicator
Ok, so for the past couple of days my "BRAKE" light has been flashing every now and then. It flashes about six times and theres a beep with the first three flashes. It only happens when Im taking an on or off ramp fast (gotta love quattro). Anyone have any ideas?? Maybe a sensor? I looked it up in the manual and it said that it might be low brake fluid pressure. Let me know.
Old Aug 26, 2005 | 05:14 AM
west2005's Avatar
Default RE: Brake Indicator
Probably low brake fluid. When you ake the turn fast, it probably trips a sensor, because the fluids are all moving around to one side or something. I had the same problem with my wiper fluid on ramps.
Old Aug 26, 2005 | 06:21 AM
PandaXpress's Avatar
check your brake pads because i had that problem then i changed my pads and it went away
Old Aug 26, 2005 | 12:14 PM
CRAZYHAWK's Avatar
Add brake fluid , West2005 is right. When pads go the indicator will always be on.
Old Oct 3, 2005 | 05:24 PM
Tlag's Avatar
I have a similar issue with the brake warning light flashing and beeping. I checked the fluid and it was full. I pulled the front passanger wheel and it look like the pads were very thin. So I purchased aftermarket OEM grade Bendix pads. I took off the caliper and removed the old pads. Well, they really weren't that worn. Hardy any wear at all compared to the new ones. I guess I couldn't see as well as I thought. The mounting plates did show flaking rust. And one of the pads separated from the steel mounting when I pulled it out. So it looks like I'll be replacing them anyway.
Are the pads with sensors available anyplace besides the dealers? The Auto Source guy said the ones he sold me were OEM grade Bendix. Maybe, but they don't have the sensor wire.
Old Oct 3, 2005 | 06:01 PM
north5995's Avatar
Not to hijack the thread here... but I am noticing my breaks are starting to squeel like they need to be replaced, but the sensor hasn't gone off. This has been happening for probably a week or so now. Any chance the sensors aren't picking it up?
I'm guessing the previous owner may have replaced the break pads with ones not compatible with the sensors.
Old Oct 3, 2005 | 06:11 PM
Heinzanova's Avatar
pads can squel, my talon had the noisest pads, and they were the highest grade ones.
Check your sensors, i was having issues, and cleaned a few sensors, and reseated the brakes and life is good.
Hondadogie
B7 Models
Apr 20, 2015 09:42 PM
T-Roc
Oct 25, 2010 07:03 PM
paturk
Jan 14, 2007 02:47 PM
r1100spa
Aug 12, 2005 05:26 AM
CRAZYHAWK
Nov 25, 2004 12:48 PM
