Buying 97 A4...what to look for?
Old Oct 26, 2005 | 03:47 AM
DTB's Avatar
DTB
Default Buying 97 A4...what to look for?
Hey I'm new to the site and I'm possibly looking to buy a 97 A4 2.8L for $7900...reasonable price? What should I look/ask for as far as common problems? I'm going to test drive it tomorrow afternoon. Thanks for your help!!!
Old Oct 26, 2005 | 03:56 AM
sandman's Avatar
Default RE: Buying 97 A4...what to look for?
make sure the timing belt has been changed
look out for
warn upper control arms
warn tie rod ends
broken sunroof
diff and valve cover leaks
Old Oct 26, 2005 | 05:58 AM
Galilee's Avatar
Like sandman said, timing belt and worn front suspension parts.
Also check brake disks for cracks, rust and wear, brake hoses and battery/battery charging.
Old Oct 26, 2005 | 12:03 PM
BLAZEDUPBEE's Avatar
SANDMAN AND GALILEE couldnt have said better. How many miles does that car have? and def get a CARFAX on it..
Old Oct 26, 2005 | 02:55 PM
InsaneHatter's Avatar
Make sure to check the CV boots as well.. they may be split and leaking grease (and for how long who knows?)
Check to make sure ALL THE SPEAKERS WORK!! sometimes they put aftermarket speakers in the rear (with non-bose) and take out the amp rendering them useless.
drive with the radio OFF for a while as well listen for any noises. A clicking when turning will be bad CV.... a clunk over potholes/bumps will be tie-rods /ends a squeak over bumps will be control arms... put the windows up and down... test the sunroof to make sure it opens and closes good (may need to be greased) Check the oil level, and all fluid levels. how does the clutch feel? (manual only) slippy at all?
HMMM what else.......
I will let you know if I think of more
Old Oct 26, 2005 | 08:27 PM
redaudi_4_life's Avatar
Wow Everyone has listed everything that has gone wrong on my car! LISTEN TO THEM!!!
Windows/ continually check them up and down at first mine worked but after I signed the papers the front two studdered, Tierods, control arms TIMING BELT! <-- that is NOT cheap! Feel for the car to have any pull, the wastegate on the turbos have been known to break. hope these help
Old Oct 27, 2005 | 12:09 AM
Sichko's Avatar
lol yep listed exactly what was wrong with my car, after haveing it for 2 months i had to replace the controll arms, engine mounts and a couple rod ends not cheap. also i would check to make sure it still has the six disk changer in the back cause i most def got a shaft on that one, u can even see the wires where it use to be.
Eric Strong
Mar 6, 2010 07:39 PM
BWillis
Dec 6, 2007 01:09 PM
beefsb89l
Apr 15, 2006 05:46 PM
beefsb89l
Nov 9, 2005 06:37 PM
