Center Driveshaft Wump Wumps
Old Mar 23, 2006 | 01:05 AM
acvega's Avatar
Default Center Driveshaft Wump Wumps
I'm getting center driveshaft vibrations at higher speeds. I've already replaced all 4 drive axles, new tires (balanced), aligned at the dealer (which they also replaced my lower control arms under recall) I have about 180,000 miles on it and at about 70-90 mph or higher it vibrates alot, been doing this for about 2-3 months, what do i need to do to fix this?
Old Mar 25, 2006 | 03:35 PM
dankhound's Avatar
Default RE: Center Driveshaft Wump Wumps
Where did you get the tires at. The audi suspension is very sensitive to tire balance and roadforce issues. You dont see alot of driveshaft balance issues. Considering the driveshaft usually runs almost a few thosand dolars i would have the tires balanced and tested for roadforce with a balancer capable of measuring roadforce. If the tires check out ok you may want to look into having the driveshaft balanced. It may not even be possible on the audi shaft.
Old Mar 25, 2006 | 03:39 PM
onepoint8tee's Avatar
ORIGINAL: acvega
180,000 miles ?! Good job.. Get your wheels balanced again before you worry about the drive shaft, and also check your tranny/engine mounts.
You might have bad/worn UV joints which can cause imbalance, that happend in an old rxy7 i had.
THis sig is stupid huh?
ozzydog
Sep 30, 2014 04:37 PM
cnigro1279
Sep 27, 2013 07:09 AM
Fox Lee
Sep 9, 2012 08:27 PM
rf_fanat1c
Aug 3, 2009 10:04 PM
jmgreen1
Jan 26, 2008 02:42 AM
