climate control problems!!
Hi,
I have a 1995 audi a4, 2.6 SE with climate control.
Just recently I have been having trouble with the cc. When I turn on the ignition the display on the right (a virtical line with 'man' over the top) flashes for about 1-2 mins and then goes normal but it won't go hot and the recirculation button only comes on when i press and hold the button, when I release the button the recirc light goes out.
Pls help!!!!!
Many thanks
ac
Pls help!!!!!
Many thanks
ac
Sorry, didn't explain very well!! The vertical line with 'man' above it is the standard display for the climate control, man meaning manual. I wish it meant a simple re-gas but as it won't go hot I'm worried its something more complicated and expensive
Thanks anyway Dave!!!
ac
ac
possibly an ambient temp sensor? i just had mine replaced cause it was bad, and my car was reading - 54 degrees when it was like 90 out. audi has a safety feature that won't allow you to use certain functions when the car is at certain temps. in my case, the AC wouldn't turn on when it was reading - 54 degrees, but when the temp sensor finally calmed down it would allow me to turn it on?
