climate control problems!!
Old Sep 18, 2006 | 04:44 PM
acuk2101's Avatar
Default climate control problems!!
Hi,
I have a 1995 audi a4, 2.6 SE with climate control.
Just recently I have been having trouble with the cc. When I turn on the ignition the display on the right (a virtical line with 'man' over the top) flashes for about 1-2 mins and then goes normal but it won't go hot and the recirculation button only comes on when i press and hold the button, when I release the button the recirc light goes out.
Pls help!!!!!
Many thanks
ac
Old Sep 18, 2006 | 04:48 PM
techbod's Avatar
Default RE: climate control problems!!
a vertical line with 'man' over the top = maintenance so a gas re-fill would be my response to the A/C
Old Sep 18, 2006 | 09:52 PM
acuk2101's Avatar
Sorry, didn't explain very well!! The vertical line with 'man' above it is the standard display for the climate control, man meaning manual. I wish it meant a simple re-gas but as it won't go hot I'm worried its something more complicated and expensive
Thanks anyway Dave!!!
ac
Old Sep 19, 2006 | 03:19 AM
BornToRun's Avatar
possibly an ambient temp sensor? i just had mine replaced cause it was bad, and my car was reading - 54 degrees when it was like 90 out. audi has a safety feature that won't allow you to use certain functions when the car is at certain temps. in my case, the AC wouldn't turn on when it was reading - 54 degrees, but when the temp sensor finally calmed down it would allow me to turn it on?
Old Sep 20, 2006 | 04:15 PM
acuk2101's Avatar
sweet, thanks for that, I'll give it a try!!
Amar
Oct 12, 2009 05:02 PM
geiz
Jun 11, 2008 07:19 AM
Outlaw427
Oct 7, 2006 06:53 PM
LTscribe
Mar 13, 2006 02:46 PM
m212dcv
Jun 3, 2005 07:39 PM
