Grinding in the rear, Bearings Shot?
Old Oct 15, 2007 | 08:32 AM
xcossx's Avatar
Default Grinding in the rear, Bearings Shot?
Hey guys, i have been having a pretty loud grinding noise coming from the rear passenger side wheel. I think it is my wheel bearing, but i have read that if it was a wheel bearing, it would be making a loud humming noise. I already ordered a wheel bearing kit and am wondering if their are any other problems that could possibly cause this grinding?
Oh and is their any detailed instructions available to dis assembling the rear hub?
Old Oct 15, 2007 | 08:36 AM
xcossx's Avatar
Default RE: Grinding in the rear, Bearings Shot?
can it also be my strut mounts?
Old Oct 15, 2007 | 12:23 PM
SAudi's Avatar
try this raise the car, grab the suspect wheel at 9 and 3 and again at 12 and 6 and see if oyu get any play. if oyu do its definelty the wheel bearing. if not take a look under the car and shake stuff around. it may just be the wheel bearing is on it last few miles. it may also be the brakes are worn.
Old Oct 15, 2007 | 12:32 PM
techbod's Avatar
also spin the offending wheel and you should hear the bearing noise, bearing noise gets louder the faster you drive
Old Oct 15, 2007 | 03:05 PM
xcossx's Avatar
alright, i jacked it up and tried shaking at 3 and 9 and 12 and 6, and there was no play. Maybe because my parking brake was on? I think it is my bearing because i only hear the grinding when making any slight or heavyright turn going over 30mph. if it was my strut mounts i would be hearing the noise constantly, right?
Old Oct 15, 2007 | 03:59 PM
S_R_N83's Avatar
worn brakes?
warped rotors?
Old Oct 15, 2007 | 07:52 PM
xcossx's Avatar
rotorsseem to be ok. not warped, maybe a caliper?
Old Oct 15, 2007 | 07:54 PM
CLX's Avatar
CLX
Zombie Defense Force
Check the condition of your pads, maybe one of them is fubar
Old Feb 2, 2008 | 08:30 PM
Apdl's Avatar
Member
I have similar issues what was the solution?
mtroxel
Mar 28, 2013 07:37 PM
Snowhunter
May 5, 2010 10:58 AM
jjcrt2
Jul 17, 2009 03:24 PM
qUaTtRoA4
Feb 3, 2008 03:15 AM
supercoupe91
Jun 22, 2007 06:51 PM
