Hard idle after battery disconnect?
Old Dec 28, 2005 | 02:01 AM
Peteman187's Avatar
Default Hard idle after battery disconnect?
I rewired the power wire for my system and when I started back up my car it had a hard idle of constant little revs. I am assuming this is normal and when I wake up tomorrow it wont happen again right? When I wired my system the first time it didn't do this.
Old Dec 28, 2005 | 03:02 AM
Karl's Avatar
Default RE: Hard idle after battery disconnect?
maybe you need to do a throttle body adaption?? I dont know.. just taking a stab in the dark
Old Dec 28, 2005 | 04:05 AM
trailboss's Avatar
Yea if you dissconnected the battery it would be wise to do a TBA, you can do it through a VAG or without it. Even after you do a TBA the rpms will bounce at idle for a little while. So yea tommorrow it will be likely that the RPMs will bounce but it should go away.
YorkshireAudiA3
May 20, 2015 08:18 PM
iheartboost
Nov 12, 2008 11:02 PM
04A6RGR
Oct 22, 2008 11:41 AM
jandouglass
Jan 2, 2008 05:18 PM
shabbey
Sep 28, 2004 01:23 AM
