HELP! Car has a mind of its own
Old Nov 19, 2007 | 09:21 PM
auditech79's Avatar
Default RE: HELP! Car has a mind of its own
You either have a malfunctioning alarm unit, or you have a bad hood/trunk/door latch.
You need a VAG COM to check for a bad latch, if you don't have one.....WHATS WRONG WITH YOU!!!??? Lol just playing take it to the dealer if you don't have one.
Old Nov 19, 2007 | 09:25 PM
Darknight101's Avatar
Its a tamper resist thing that alot of companys put in. If the voltage is to low then they just flip out. Every once in a while if your board and have no fear of shorting stuff out you can take a screw driver to the grounds close to the alarm box, theres a few that will go off for a load change as far as a 100% reason I have no clue thats just from playing around in a lab hehe.
I whould take it in for a load test it dosent take long and Autozone will do it just go where there not busy or the get pissie with ya. My secound thing is probley a short a half azzed attempt at an install with tape and some nuts probley done by a newbie taping in someware.
Old Nov 19, 2007 | 09:39 PM
njtrackstar's Avatar
it started about a week to two weeks ago. it went off once and then the rest of the night it was fine. and slowly happens more and more. so im hoping it just the battery, it kinda makes sense to be that. or is it just me?
Old Nov 19, 2007 | 09:50 PM
auditech79's Avatar
It makes absolutely no sense that its the battery. Think about this, if the alarm were armed and the door latch lets say malfunctions and thinks the door is open the alarm is gonna fvcking go off!!!!!!
Old Nov 19, 2007 | 09:55 PM
Good point auditech79 forgot about that as well. Had an old geo that had that happen to me the door latch was lose and it cause all sorts of stuff to flip out. Your the Man as normal.
Old Nov 20, 2007 | 09:35 AM
ok so im getting ready for school today. I go to the window to start the car. it turns over very slowly then just does not start the car. So i am replacing the battery today and hopeing it gets rid of the alarm problem.
Old Nov 20, 2007 | 10:43 AM
rbrtech's Avatar
I have to agree a door lock acuator is not an uncommon problem and causes you symptoms
Old Nov 20, 2007 | 11:57 AM
  #18
well how would i fix this? is it a DIY or a dealer job? how much would this cost?
Old Nov 20, 2007 | 01:04 PM
  #19
hiwords's Avatar
http://vag-tool.kicks-***.net/
check if any in ur area has vag com on that site. it can check evry single thing on ur car. that will check if all the door latches are good. if they all good, u need to check the wiring for ur alarm. if that's all good, u need to check for shorted wires behind the radio. if that's all good then i think u should remove that alarm and put the factory one on and see wut happens. if u don't have the factory one anymore, idk wut else to tell u lol. can't think of anymore but if i do i'll get back
niceguy101
Jun 16, 2008 11:53 PM
AudiOmaha
Mar 14, 2008 09:20 AM
QuattroPhilly
Feb 19, 2008 09:38 AM
scotts custom
Jan 14, 2007 02:52 AM
Heinzanova
Nov 18, 2005 10:00 PM
