interior light issue
Old Sep 27, 2007 | 08:07 AM
jmm96gsr's Avatar
Default interior light issue
I just recently bought a '04 A4 1.8T. When I first got the car, the overhead interior light would come on when you open the door, then when you started the car it would slowly dim out. It would do the same when you opened the door and then dim out when you locked the doors. Now, the light will stay on the whole time including when you lock the doors. The switch for the light is still in the center position just like when it use to dim out automatically. Also, now the hazard light switch on the dash stays lite even if you switch every light off and lock the doors. The rear window safety switch on the drivers door does the same- stays lit when every thing else is off and the car is locked. Any ideas?
Old Sep 28, 2007 | 07:59 AM
jmm96gsr's Avatar
Default RE: interior light issue
Anybody?
Old Sep 28, 2007 | 08:54 AM
hiwords's Avatar
well the overhead lights might not be turning off because there's a switch in the door that dims them out after u close the door. the switch might not be workin. as for evrything else im not too sure but something might have shorted
Old Sep 28, 2007 | 09:11 AM
jmm96gsr's Avatar
Thanks for the response. I need to really take a look at it this weekend. The overhead light, and the two switches are somehow getting a low voltage even though anything else is turned off. If I have the overhead light at the center position and switch it to the on position, I can see the light get lights get brighter. I guess I will look at relays or fuses related to the comfort system module. I printed off wiring diagrams and component locations that I need to take a look at.
thehawkishowling
Nov 21, 2013 12:56 AM
GTR21
Nov 22, 2012 03:40 AM
Seastrike
B7 Models
May 12, 2011 03:50 PM
knaviaux
Jan 21, 2009 05:15 PM
moe485
May 7, 2008 12:23 AM
