lean questions
Old Oct 10, 2006 | 10:07 PM
david9999's Avatar
Default RE: lean questions
How do you know you are running lean? Codes?
How many miles on your car? Could be that your fuel filter is getting clogged.
Old Oct 10, 2006 | 11:00 PM
chuckievi's Avatar
Last time my vag worked and I could get a code I was running lean, thats all it said so I followed the advice and did the maf/leaky hose thing. My car has 92kish miles on it, a little less I think, but like I said the hoses were all shot to crap, so I don't know what else could need replacing that I just didn't see. See, boost gauges DO help, if I hadn't put it in I woulda had those beat to all hell lines still there.
Old Oct 10, 2006 | 11:23 PM
david9999's Avatar
Vacuum leak would cause a lean additive code.
Clogged injectors would cause a lean mult code.
Fix your vacuum lines and throw in some good injector cleaner (techron or redline) and see if codes return.
Old Oct 10, 2006 | 11:25 PM
chuckievi's Avatar
I think tonight is make the vag work so I can get the code night.
shellsaudi7706
Jul 9, 2008 05:51 PM
auditt225
Jul 29, 2007 05:21 PM
spam7788
May 23, 2006 08:53 PM
True_Pinoy
Jan 10, 2006 06:41 PM
Vader
Oct 26, 2004 12:32 AM
