New Fault Codes... NEED ADVICEW!
Old Feb 10, 2006 | 09:51 PM
dragondesigns's Avatar
Default New Fault Codes... NEED ADVICEW!
Fellas.... Here are some new fault codes I'm getting on my 99 A4 - 2.8L
18010 P1602 POWER SUPPLY B+
17967 P1559 THROTLE POSITION SENSOR
16826 P0442 EVAPORATIVE EMMISSION SYSTEM. SMALL LEAK
Give me some ideas on what could be the problem and the most cost-effective way to fix.
Thanks guys!!!!
Old Feb 11, 2006 | 03:55 PM
AudiTech04's Avatar
Default RE: New Fault Codes... NEED ADVICEW!
Erase the codes and drive it, see what ones come back
Old Feb 11, 2006 | 04:15 PM
techbod's Avatar
18010 P1602 POWER SUPPLY B+ "you disconnected the battery??"
17967 P1559 THROTLE POSITION SENSOR "as above you lost the data"
16826 P0442 EVAPORATIVE EMMISSION SYSTEM. SMALL LEAK "leak in vacuum pipe replace vacuum pipes"
Old Feb 12, 2006 | 12:42 AM
dan's Avatar
dan
HEY! where do i buy that translation module for VAG-COM?
m.c.
May 2, 2012 01:40 PM
1Move
Dec 1, 2007 05:37 PM
paulrob2808
Aug 28, 2007 04:18 PM
mitao2000
Aug 30, 2006 11:53 AM
BaconBait
Aug 8, 2005 08:21 PM
