New Fault Codes... NEED ADVICEW!
Fellas.... Here are some new fault codes I'm getting on my 99 A4 - 2.8L
18010 P1602 POWER SUPPLY B+
17967 P1559 THROTLE POSITION SENSOR
16826 P0442 EVAPORATIVE EMMISSION SYSTEM. SMALL LEAK
Give me some ideas on what could be the problem and the most cost-effective way to fix.
Thanks guys!!!!
Thanks guys!!!!
18010 P1602 POWER SUPPLY B+ "you disconnected the battery??"
17967 P1559 THROTLE POSITION SENSOR "as above you lost the data"
16826 P0442 EVAPORATIVE EMMISSION SYSTEM. SMALL LEAK "leak in vacuum pipe replace vacuum pipes"
