over Heating Problem
Hi I'm new & This Is My first post, I need help.
I own a 2005 Audi A4 Quattro 1.8
And it has Over Heating Problems
It tells me it need coolant but we put some and it all leaked off, then 5 minutes later tells me the same.. Ugh it's my first car please help
It is leaking coolant from the rear, what are the consequence of an over heating car? People tell me it might be the heads and that after it gets fixed I won't be able to drive it on a long road trip cause it will mess up, is this true?
Just get a good high powered flashlight and let it warm up a little and lok for where it begins to leak. It sounds like you will not be the one to wrench on it so sooner you bring it to a shop the better. They can pressure test it. It could be something simple as a temp sensor popped out or o-ring not put seated.
You will only warp the head if you let it get super hot and try and drive it or something.
