over Heating Problem
Old Aug 21, 2012 | 07:26 PM
denisse20's Avatar
Default over Heating Problem
Hi I'm new & This Is My first post, I need help.
I own a 2005 Audi A4 Quattro 1.8
And it has Over Heating Problems
It tells me it need coolant but we put some and it all leaked off, then 5 minutes later tells me the same.. Ugh it's my first car please help
Old Aug 23, 2012 | 02:22 AM
Inflowmini's Avatar
there are several reasons why the coolant leaks. it can be a cracked coolant expansion tank. the radiator might cracked,or the coolant flange is also cracked. look where its leaking coolant front of engine, side or the rear
Old Aug 25, 2012 | 12:18 AM
denisse20's Avatar
It is leaking coolant from the rear, what are the consequence of an over heating car? People tell me it might be the heads and that after it gets fixed I won't be able to drive it on a long road trip cause it will mess up, is this true?
Old Aug 25, 2012 | 02:59 PM
Inflowmini's Avatar
So it might be the coolant flange, that is easy to replace and not very costly, and do not drive the car when its overheating, your whole engine will be damaged (warped head maybe) and it will be a pain to fix.
Old Sep 13, 2012 | 12:43 AM
A4inMaui's Avatar
Just get a good high powered flashlight and let it warm up a little and lok for where it begins to leak. It sounds like you will not be the one to wrench on it so sooner you bring it to a shop the better. They can pressure test it. It could be something simple as a temp sensor popped out or o-ring not put seated.
You will only warp the head if you let it get super hot and try and drive it or something.
DaveQ7
Audi Q7
Sep 16, 2014 01:58 PM
Julianpnc
Oct 23, 2012 04:15 PM
Paul Rasmussen
Oct 10, 2012 08:51 PM
plumbous
Dec 15, 2009 10:19 AM
jj2345
Aug 21, 2009 11:06 PM
