Partial half a$$ed CV axle DIY *pics*
Old Jan 28, 2008 | 11:29 PM
qUaTtRoA4's Avatar
Default Partial half a$$ed CV axle DIY *pics*
So, I had a mad click that I thought was coming from my CV axles, even though the boots wern't torn, I just figured that they somehow slowly ran themselves dry after 10 years...
so, I went to purems.com and almost 300$ later I had the two new front axles on my doorstep.
so, here's a partial DIY, if someone wants to add to it and make it an official DIY, fell free to quote me and take my pics.
1) loosen 17mm alen bolt that connects the axle
2)loosen lug nuts
3) jack up car and remove wheel
4) remove 16mm pinch bolt using 16mm wrenches or sockets
5) with a rubber mallet tap connecting arms up until they come up loose from the pinch "deal"
6) using a 8mm tripple square remove the 6 bolts holding the axle to the trans.
7) pull the abs speed sensor straight out
8) strat loosening the 14mm axle bolt, then tap it in (pushing the axle in)
9) bend the joint of the axle and remove.
-now repeat everything in reverse....
special thanks to Kyle (pyropenguin) for doin all the fun stuff for me
hope this helps someone eventually...
shoulda taken more pics, but oh well...
the old passenger side wheel end CV boot was not torn but was filled with water!
Old Jan 28, 2008 | 11:36 PM
hiwords's Avatar
Default RE: Partial half a$$ed CV axle DIY *pics*
o nice, you didn't even do any work and wrote a diy lol
Old Jan 28, 2008 | 11:39 PM
qUaTtRoA4's Avatar
lol....I lubed the avles and drank a few rolling rocks...I probably did some other things as well, but I was mainly a supervisor...
I think I pinched a nerve in my back, It might sound like a sh!tty excuse, but just wait until it happens to you...
Old Jan 29, 2008 | 12:08 AM
Rhinop21's Avatar
I pinched a nerve in my tricep I wanted to cry for hours.
Old Jan 29, 2008 | 12:24 AM
SAudi's Avatar
you know theres already a DIY on audidiy.com also good call on replaceing the whole axle instead of the joint only, its alot easier less dirty and you have 2 new axles instead of rusty ones.
Old Jan 29, 2008 | 12:32 AM
auditech79's Avatar
I think i might add, that its a 17mm allan bolt, not a 14mm axle nut.
Old Jan 29, 2008 | 12:39 AM
qUaTtRoA4's Avatar
ORIGINAL: auditech79
thanks, I fixed that above...I thought it was 14mm, but couldn't remember because it was a tool I had to borrow and no longer have. and hopefully wont need for another 10 years.
And definately replace the whole axle, it's a whole lot easier and then you know it's brand new and you have no CV worries!
Old Jan 29, 2008 | 12:40 AM
qUaTtRoA4's Avatar
ORIGINAL: qUaTtRoA4
lol....I lubed the axles and drank a few rolling rocks...I probably did some other things as well, but I was mainly a supervisor...
quattro179
B7 Models
Jun 30, 2011 09:50 AM
nitrorocket
Nov 19, 2010 01:30 AM
SouthernAudi
Mar 19, 2008 12:43 AM
Mac_17
Dec 12, 2007 06:14 PM
quattrosedan
Jan 20, 2006 12:16 AM
