Power Steering FLuid Change- help needed
Old Nov 1, 2007 | 12:47 AM
ramiajjuri's Avatar
Default Power Steering FLuid Change- help needed
i have an '02 a4 1.8T quattro and i need to change my steering fluid I THINK.. is there a way i can check before and after to see if that's what i needed? what kind do i use and where do i pour it? do i need to drain the old fluid out? love my car, but don't know **** about it. everyone has to start somewhere. please help me out. thanks.
rami ajjuri
Old Nov 1, 2007 | 09:50 PM
96A4Owner's Avatar
Default RE: Power Steering FLuid Change- help needed
ya man i have the same dilemma, i'm pretty sure too that is the power steering. And you only add fluids to it, you don't drain them out. When you do add the fluids, make sure you car is running too or else you'll blow out some gasket things.
Old Nov 1, 2007 | 10:23 PM
wolfdog's Avatar
I was thinking about doing this but it's not a priority. I think what I'm going to do when I get around to it is turkey baster the reservoir empty and fill. In a few months I'll come back and repeat. That should get most of it replaced. I forget who posted that technique but it seems easy and painless. I'll be using Pentosin CHF 11S.
Old Nov 1, 2007 | 11:15 PM
david9999's Avatar
Pentosin 11 fluid. Do not use ATF or "power steering fluid". I change mine the clean way, although it is not a full drain. Every 10K miles or so I use a turkey baster to drain the reservoir and pour in fresh fluid. It is not anywhere close to a full drain and fill, but it gets some of the dirty stuff out. I'm now at 190K miles at PS pump is fine.
Old Nov 2, 2007 | 08:55 AM
CRAZYHAWK's Avatar
The engine should be off, when checking and adding the CHF11S.
jeeplover38
Oct 31, 2010 01:34 PM
cipherchris
Apr 1, 2007 02:21 PM
ryanisaninja
Mar 11, 2007 06:43 PM
thrax982
Mar 31, 2005 10:15 PM
