Shift points
Old Nov 3, 2007 | 12:13 AM
badjoke's Avatar
Default RE: Shift points
ORIGINAL: Trey25
5000. Theres a flat spot after that so you won't be making any power. Keep in mind that the trans USUALLY refuses to shift from 3-4-5 at WOT. You'll have to ease off like a manual or it'll hit the rev limiter.
Thanks a lot.
Old Nov 3, 2007 | 12:15 AM
sineo's Avatar
ORIGINAL: bob12312357
Most women can't drive stick.j/k ohhhhhhh shiznit lol
Calm down.
Old Nov 3, 2007 | 12:38 AM
onepoint8tee's Avatar
ORIGINAL: Trey25
Redline is best for max power. It will make sure that when you get into the next gear your rpms will be higher for more power. You have NA so you shouldnt have a real power drop above 5k rpms or significant heat soak. Your tranny should not refuse to shift from 3-4-5 at WOT. Maybe a tcu problem.
Old Nov 3, 2007 | 05:06 AM
badjoke's Avatar
So which is it? That's a difference of 1,500 rpms.
Old Nov 3, 2007 | 08:41 AM
sineo's Avatar
Why don't you experiment and learn by doing? It'll mean a lot more than specific numbers on a web page.
Old Nov 3, 2007 | 11:02 AM
Trey25's Avatar
ORIGINAL: onepoint8tee
That flat spot after 5500 is well known on the 2.8. Why go all the way to redline when the optimal shift point has been passed? (rhetorical) Let me clarify. The trans doesn't just refuse to shift, it hesitates. But only at high speeds and WOT. This is also common on the 2.8 tip. Theres nothing wrong with the tcu. All that said I think audi's tip is one of the most responsive. I've driven a few "tip" acuras and bmws and they all kinda suck.
Old Nov 3, 2007 | 12:57 PM
ORIGINAL: Trey25
The B5 tip is the very least responsive when copared with later platform A4 tips, and pretty much any other tip car except for dodge/chrysler/gm tips. Show me a dyno sheet that shows power significantly dropping at 5500 rpms. I know there is a flat spot, but Im doubting that its taking away as much power as you think it does, resulting in the need for an earlier shift, causing you to start the next gear at a lower rpm than necessary for what your trying to accomplish (fastest acceleration). If your tranny is hesitating at any point during the powerband, you have either a mechanical or tcu issue. Just because something may be common, that does not make it"normal" by any means.
Old Nov 3, 2007 | 02:08 PM
  #18
chaos92287's Avatar
lol that should be Audi's new slogan
itsmatt33
Jun 27, 2008 07:35 PM
Red_sapphire89
Mar 20, 2008 01:59 AM
stef2.7t
Oct 24, 2007 09:03 AM
Karl
Aug 7, 2006 07:13 PM
rescueswimmer07
Sep 12, 2005 05:42 PM
