Temp sensor
Old Jan 12, 2007 | 04:24 AM
  #21
BadLuckAudi's Avatar
Default RE: Temp sensor
ORIGINAL: onepoint8tee
ORIGINAL: fcanozo
I'll pug the old sensor bask to see if the temp gauge work again, if it, the new sensor is defective becouse the old one give me a code but the temp gauge was working fine.
What do you think?
I think thats a good idea.
yea that sounds like a good idea man, at least then you will know if the sensor is toast or maybe the guage went
Old Jan 12, 2007 | 12:36 PM
  #22
fcanozo's Avatar
the only think I will miss that extra power, since that, my babe is stronger, more powerful.
Old Jan 12, 2007 | 05:58 PM
  #23
onepoint8tee's Avatar
ORIGINAL: fcanozo
When my temp sensor went bad my temp gauge read normal. So if your temp gauge reads normal after you put the old one back in and you get the fault code again with noticeable performance decrease id just buy another new one or try to return the old new one.
Old Jan 12, 2007 | 06:09 PM
  #24
techbod's Avatar
changed the thermostat/ temp sender sensor/ plenty heat in the cabin/ no overheating/ no loss of coolant I would guess a faulty dash reading or sticking gauge
Old Jan 12, 2007 | 06:51 PM
  #25
fcanozo's Avatar
Do you think is a good idea to vag the car? because the check engine L. went off by itself before I replace the temp. sensor.
Maybe the light went off but the code is there and it's giving fase readings
Old Jan 12, 2007 | 06:53 PM
  #26
techbod's Avatar
light off = no problem
Old Jan 12, 2007 | 07:28 PM
  #27
ORIGINAL: fcanozo
Yes always get the codes cleared after you fix the problem and CEL is off. This way next time something breaks you wont have old fault codes stored that may confuse you. Always record your fault codes and date them. I keep a notepad doc on my desktop where i record all mine and note what diagnosing steps were taken to fix it or what was tried.
Old Jan 12, 2007 | 09:15 PM
  #28
fcanozo's Avatar
that's a smart move!
toboater
Oct 26, 2010 12:15 PM
bmr18t
Dec 4, 2008 11:09 PM
carhopper
Aug 23, 2007 07:21 AM
