wheel bearing replacement question
Old Mar 5, 2006 | 05:39 PM
pitobaby76's Avatar
Default wheel bearing replacement question
ok so im going to replace one of my rear wheel bearings and bought the kit that comes with a new axle bolt. can i reuse all the other hardware or is there anything critical that i must replace? thanks.
Old Mar 5, 2006 | 06:35 PM
dankhound's Avatar
Default RE: wheel bearing replacement question
You can reuse everything. Even the bolt if you have too. Although i would recommend replacing it since you have it. Dont forget those bearings are press fit so youll either have to find a press or get the tools to remove them.
Old Mar 5, 2006 | 11:05 PM
pitobaby76's Avatar
thanks, thats what i was hoping. i have a press at my job so im gonna take advantage.
Old Mar 29, 2006 | 05:57 PM
mckenzjs's Avatar
hi, how did you diagnose your wheel bearing problem? i have a 2001 s4 and there seems to be a whinning sound coming from one of the back tires, not really loud and bearly noticable. i have no shimmy at all. does this sound like a bearing issue? an a4 friend of mine said that was exactly how his bearing was discovered and went away when replaced. thanks.
scott
Old Mar 29, 2006 | 06:44 PM
InsaneHatter's Avatar
sounds like a bearing to me
Old Mar 29, 2006 | 06:51 PM
black991.8tq's Avatar
ORIGINAL: mckenzjs
scott
yep sounds right to me.
Old Mar 29, 2006 | 08:23 PM
fastmayte's Avatar
what they said ^^^^
Old Apr 2, 2006 | 12:24 AM
dankhound's Avatar
Try swearving back and forth on a straight road. If its a bearing the noise should get louder when you sweave in one direction and quieter or gone when you swearve in the other direction.
Dads Ride
Nov 11, 2008 08:40 AM
bob martin
Feb 21, 2008 04:50 PM
DjDiddles
Jan 10, 2008 02:04 PM
xcossx
May 8, 2007 03:07 PM
fritz
Apr 26, 2006 01:30 PM
