Sponsored by:
Sponsored by:
wheel bearing replacement question
Old 03-05-2006, 05:39 PM
pitobaby76's Avatar
Default wheel bearing replacement question
ok so im going to replace one of my rear wheel bearings and bought the kit that comes with a new axle bolt. can i reuse all the other hardware or is there anything critical that i must replace? thanks.
Old 03-05-2006, 06:35 PM
dankhound's Avatar
Default RE: wheel bearing replacement question
You can reuse everything. Even the bolt if you have too. Although i would recommend replacing it since you have it. Dont forget those bearings are press fit so youll either have to find a press or get the tools to remove them.
Old 03-05-2006, 11:05 PM
pitobaby76's Avatar
thanks, thats what i was hoping. i have a press at my job so im gonna take advantage.
Old 03-29-2006, 05:57 PM
hi, how did you diagnose your wheel bearing problem? i have a 2001 s4 and there seems to be a whinning sound coming from one of the back tires, not really loud and bearly noticable. i have no shimmy at all. does this sound like a bearing issue? an a4 friend of mine said that was exactly how his bearing was discovered and went away when replaced. thanks.
scott
Old 03-29-2006, 06:44 PM
InsaneHatter's Avatar
sounds like a bearing to me
Old 03-29-2006, 06:51 PM
black991.8tq's Avatar
ORIGINAL: mckenzjs
scott
yep sounds right to me.
Old 03-29-2006, 08:23 PM
fastmayte's Avatar
what they said ^^^^
Old 04-02-2006, 12:24 AM
dankhound's Avatar
Try swearving back and forth on a straight road. If its a bearing the noise should get louder when you sweave in one direction and quieter or gone when you swearve in the other direction.
Dads Ride
11-11-2008 08:40 AM
bob martin
02-21-2008 04:50 PM
DjDiddles
01-10-2008 02:04 PM
xcossx
05-08-2007 03:07 PM
fritz
04-26-2006 01:30 PM
Quick Reply: wheel bearing replacement question
