Xenon and other
Last one...by the way I will be replacing the license plate holder with a straight plastic bar. The dealership will order the part for me, hopefully it'll be free!
[IMG]local://upfiles/6391/955F13E8887448DD89B42D0D0110A82E.jpg[/IMG]
ORIGINAL: mrfredo82
I have also fitted the Silverstars and they are way better and a lot whiter than the standard bulbs. I drive a B5 A4 now but had a B6 A4 before and I would say the Silverstars come pretty close to the B6's projector style lights in illumination. BTW, in South Africa, the Silverstars are about $17 a set of two H4 bulbs.
When changing over to HID it is not always as easy as just putting in the ballast, igniters, and hid capsules. If your wanting just the look then yes that is all u need but to get the full effect you will need the projectors from the oem counterpart as to take advantage of the higher lighting output.
Without the original projectors from the hid light housings you will have alot of wasted light and glare which can be dangerous to oncoming traffic and thus making yours not as good as the real deal.
Well lets just say I want the xenon look without having to change over to HID. I have a B7 A4 with no xenon, I didnt get the lights package. But I want the xenon look on my car? Should I just get Silverstars? Are they just bulbs that you replace? Do I have to replace the high beam, low beam, fog ligts? How much per bulb?
I would like to know how I solved the problem of xenon in my car because when I ignite the xenon system the car to me it gives an error me of the brakes and single it happens to me when I ignite xenon. i want to know if a cant put xenon in my audi a4. i want to know what kind of xenon I can installed
I need help with that thanks a lot.
PartsPro0101
Jul 30, 2008 08:22 PM
