1997 A6 Instrument Panel Illumination
Hi,
new owner of a 1997 A6 and I am unfamiliar with the IP Illumination. I have two problems:
1 - The Automatic Transmission PRNDL indicator does not light up when the headlights are on - is this normal or is it burned out?
2 - The odometer does not light up whether the headlights are on or not
My question is are there bulbs that are replaceable in order to make these 2 components light up or must the components themselves be replaced? Must the entire IP be replaced? How does the odometer register the correct mileage once it is replaced? I have the Ross-Tech VCDS unregistered software and would pay for the registered version if necessary to redo the odometer
Thanks in advance for any advice
Paul
Paul
The good news is you have a `97 which means you can actually buy individual components for it...unlike later models. The "PRNDL" display is a separate illuminated module, so there is no replaceable bulb. I'm not completely sure about the odometer light, but I know there are lots of serviceable bulbs within your cluster.
Good Luck!
UberTeile
Good Luck!
UberTeile
