1997 A6 Instrument Panel Illumination
Old Nov 24, 2010 | 12:41 PM
niknak's Avatar
Default 1997 A6 Instrument Panel Illumination
Hi,
new owner of a 1997 A6 and I am unfamiliar with the IP Illumination. I have two problems:
1 - The Automatic Transmission PRNDL indicator does not light up when the headlights are on - is this normal or is it burned out?
2 - The odometer does not light up whether the headlights are on or not
My question is are there bulbs that are replaceable in order to make these 2 components light up or must the components themselves be replaced? Must the entire IP be replaced? How does the odometer register the correct mileage once it is replaced? I have the Ross-Tech VCDS unregistered software and would pay for the registered version if necessary to redo the odometer
Thanks in advance for any advice
Paul
Old Nov 24, 2010 | 02:52 PM
UberTeile's Avatar
The good news is you have a `97 which means you can actually buy individual components for it...unlike later models. The "PRNDL" display is a separate illuminated module, so there is no replaceable bulb. I'm not completely sure about the odometer light, but I know there are lots of serviceable bulbs within your cluster.
Good Luck!
UberTeile
Old Dec 4, 2010 | 10:56 PM
niknak's Avatar
Thanks for your help! I appreciate it
Old Mar 19, 2014 | 11:32 PM
fenton's Avatar
there is a brilliant presentation on you-tube showing how to replace the centre LED screen, should be ok for anyone with average skills
bonestock3
Dec 5, 2010 04:12 PM
alberta-s4
Nov 7, 2010 06:06 PM
sdiegidio
Aug 4, 2007 05:23 PM
descarl
Feb 10, 2007 10:51 AM
CrazyRussian540
Dec 21, 2006 02:04 AM
