2006 Audi A6 3.0L has one code
Old Sep 4, 2010 | 10:47 AM
millenia's Avatar
Default 2006 Audi A6 3.0L has one code
Hi everyone, I'm a dealer in Syracuse, NY specializing in Audis, typically reselling them. I got an 03 a6 in this week and it's got code p0600. The car has check engine light on, abs and esp light on and tiptronic wont work, also when you turn the key to start the car, it says please press clutch to start, but the vehicle is an automatic and i checked with the Audi dealer to make sure the cluster was for an automatic and they confirmed it is an automatic. the code P0600 is serial link error code. Anybody who had this issue please reply, I searched around the net and haven't found anything regarding this problem.
Old Sep 4, 2010 | 07:00 PM
ImTheDevil's Avatar
Have you confirmed that the ECU is from a tip car? I don't see how it'd run unless it was but that's a really strange code and symptom to see. It's possible you have an issue with the TCU though - the P0600 could mean an issue communicating with the TCU. It would also explain the lack of tip function and possibly the ESP issue. Check the TCU for signs of water intrusion or wiring harness corrosion - they're susceptible under the carpet.
Old Sep 27, 2010 | 10:18 PM
millenia's Avatar
good news, issue is fixed, one of my guys found the box where the transmission computer is, and it was completely soaked in water, new module took care of the issue.
g.ryan
Aug 15, 2017 01:51 PM
kamleshkumar
Jul 8, 2015 12:37 PM
demick514
Apr 15, 2014 08:01 PM
fondoo
Apr 26, 2010 12:57 PM
bigsnowdog
B7 Models
Apr 14, 2008 01:01 AM
