Audi A6 2.7T Issues
Old Jul 2, 2010 | 10:28 PM
russdog29's Avatar
Default Audi A6 2.7T Issues
I recently purchased a 2004 A6 2.7T and I have noticed that the vehicle is having a hard time shifting during rapid acceleration. This only occurs while my shifter is in its normal automatic position and I have yet to see it happen while in tiptronic mode. The other odd issue that I have noticed is that during rapid acceleration air is forced through the defrost vents in the dash whether or not I have the a/c on. I'm guessing that the ventilation issues are due to a blown vacuum switch, but could the two be related?
The car has been well maintained and only has 70,000 miles on it currently.
Is there anyone out there that could provide some insight to what may be occuring with my car?
Old Jul 7, 2010 | 09:54 PM
russdog29's Avatar
I'm still looking for some help from anyone who might have an idea as to what is going on with my car. Thanks!
Old Jul 8, 2010 | 06:46 AM
02A6Beau's Avatar
could be a whole bunch of stuff.
have you tried pulling codes? I would suggest you start there and see what your car thinks might be going on with itself.
Old Jul 8, 2010 | 07:48 AM
oldmots's Avatar
You might check vacuum connections to the reservoir and put a guage on it to check it to be sure you have vacuum in the system, an easy thing to do. After that, you need a scan of the sensors in real time to look for the cause.
Old Jul 9, 2010 | 09:35 AM
bob martin's Avatar
The transmission shift lag is probably normal. There are something like 200 maps in the transmission and yours has probably selected a conservative map, which results in a slow downshift. Either drive more aggressively to force a map change or stick to Tip mode for the aggressive times.
I can be no help on the air through the vents issue.
Bob
voodoodsn
Jan 8, 2014 01:03 PM
tofast2belast
Sep 19, 2012 06:08 PM
OZAudi90
Jun 28, 2008 09:57 AM
Danwilliambiba
Jan 3, 2008 06:28 PM
kenestle
Dec 4, 2004 08:31 PM
