audi a6 question
Old Oct 1, 2007 | 02:57 PM
metal face's Avatar
Default audi a6 question
hi there im new to all this i hace a audi a6 2.6se on a 1995 plate i would just like to know if anyone could tell me roughly what the bhp is and what miles the cambelt should be changed thanks alot
Old Oct 1, 2007 | 03:07 PM
techbod's Avatar
Default RE: Audi a6 question
150 HP and timing belt to be checked every 37K ( there is no change time as its supposed to be non interference engine
Old Oct 1, 2007 | 03:36 PM
metal face's Avatar
hi again wat do you mean by non interference engine
Old Oct 1, 2007 | 03:43 PM
techbod's Avatar
that means the chances of are valve strike when the timing belt snaps is a lot less thean interference engine which in most cases is guaranteed
Old Oct 1, 2007 | 04:04 PM
metal face's Avatar
well the cambelt was changed at 90000 its now hit 140000 so do u think its time to get it changed
Old Oct 1, 2007 | 04:12 PM
techbod's Avatar
I cant really answer that question because Audi don't have a time/mileage limit to change it so its down to you ( personally I would stick to 90k changes ) and check condition every half of that
Old Oct 1, 2007 | 04:18 PM
metal face's Avatar
ok thanks ever so much for your help really appreciate it
Old Oct 1, 2007 | 04:42 PM
techbod's Avatar
Toothed belt for camshaft drive: checking for damage, measuring width of toothed belt (4-cyl. TDI engines up to and including model year 1999 -X-)
Release the two tensioning clips at the top of the toothed belt cover and upper edge of cover forwards.
Check condition of toothed belt for:
t
Cracks, cross-sectional fractures
t
Layer separation (toothed belt body, cord strands)
t
Break-up on toothed belt body
t
Fraying of cord strands
t
Surface cracks (synthetic coating)
t
Traces of oil and grease
WARNING[/align]
Any faults found must be rectified (repair measure).
Measure toothed belt width -a-.
t
Wear limit = 22 mm
WARNING[/align]
If width of toothed belt is less than 22mm it is essential that you renew the toothed belt (repair measure).
[IMG]local://upfiles/12092/B1B54D7F9CE04F25B152DFC2867DF19D.jpg[/IMG]
Old Oct 1, 2007 | 04:44 PM
techbod's Avatar
even though that's for the 4 cylinder the procedure for checking the belt is the same
Gavica
Feb 6, 2017 12:07 PM
G2SSM
Feb 22, 2013 08:10 PM
KKAuto
Aug 4, 2009 06:31 PM
manindra
Feb 10, 2009 05:59 PM
Madcrazy10
Jan 23, 2006 11:29 PM
