Brake Question
Old Dec 6, 2007 | 10:28 AM
bchena1313's Avatar
Default Brake Question
Where can i find out which brake pads and rotors to get? My rear brakes are toast as well as my rotors, so i am looking to save a few bucks and buy them myself and have them put on. My mechanic is charging me 250 to install brake pads, rotors, and rr caliper...does that sound like a good price for install?
Old Dec 6, 2007 | 11:36 AM
Jeffla's Avatar
Default RE: Brake Question
I bought my brakes from www.getcoolparts.com for my 2.8l. If you use coupon code audi06 and you save 5%.
Jeff
Old Dec 6, 2007 | 12:21 PM
formulagigi's Avatar
get SS brake lines while you're doing the work. Think I paid 130+ for mine, well worth the $, then replace yuor brake flui with the top of the line Motul
Old Dec 7, 2007 | 11:18 AM
hxgaser's Avatar
Check out www.buybrakes.com. I really had good experience with them, and you can pretty much order anything. As for the parts, I always use simple Brembo blank rotors and Hawk HPS pads. Hawk HPS has very linear braking power, with soft initial bite. But when you need it, it works way better than the stock IMO. But let me warn you that it does generate quite a bit of dust. If you don't want the dust, then go with a ceramic pad of some sort, but I noticed that the braking power isn't that good. good luck.
Old Dec 7, 2007 | 07:17 PM
DjDiddles's Avatar
I'm in the exact same process right now! I found rotors on bimmerspecialist.com for $27 and pads for $57. Good luck!
Old Dec 7, 2007 | 07:25 PM
paaudia6's Avatar
Member
definitely would'nt get $27 rotors for your audi i would go with a quality rotor like zimmerman or brembo
Old Dec 10, 2007 | 09:16 AM
bchena1313's Avatar
I am having a hell of a time trying to figure out my brake size. On the little white sticker it says 1KD which is the only code i see that matches any brake codes. Does anyone know which size i have? 2001 2.7T Q. I dont know if i have 245mm or 255mm...HELP.
Old Dec 10, 2007 | 11:54 AM
nemohm's Avatar
I’d call dealers with VIN
Would ask for a quote; ask for info on the specs you need to know!
There is a Built code for A6 -ON5, ON6 as they come in two base dimensions and two bearing/hub sizes.
What is the calipers rebuild for?
Rear brake job -disks, pads, labor for $150 seems to be ok. The rest: Rebuild calipers (parts, labor), bleeding the system for $100 ?!?
Old Dec 10, 2007 | 12:37 PM
NH_USA's Avatar
If he is getting a rebuilt rr caliper for $100 the price is about right.
Other parts - rotors $60 a set, pads $40 - leaves $50 for labor.
That sounds reasonable... Just remember the rebuilt caliper usually comes with pads that are barely. You'll still need pads for the left side sohave the good ones put on.
Quattro_1.8t
Jun 10, 2008 08:37 PM
jayson161
Jan 21, 2008 03:02 AM
tyleryours
Jun 1, 2007 06:16 PM
Barrington
Mar 22, 2007 06:25 PM
cannon64
Jan 16, 2007 02:56 AM
