Brake Rotor Replacement
Old Jul 15, 2007 | 07:46 PM
kbunting's Avatar
Default Brake Rotor Replacement
How difficult is it to replace the brake rotors on a 2000 A-6 Quatoro Twin Turbo 2.7.
I replaced the front pads today and it looks like the front rotors would come right off once the caliper is removed. The rear rotors seemed very solid. Are they held in place by the center bolt or are they just rusted on which maybeis whyI couldn't get them to move on the hub?
Would like to replace all 4 rotors in the spring and wondering if this is something I can do at home or if special tools are required.
Thank you,
Kurt
Old Jul 15, 2007 | 08:48 PM
auditech79's Avatar
Default RE: Brake Rotor Replacement
To pull the entire brake rotor you have to take off those two 21or21mm bolts and swing the caliper assembly out of the way, then there should be a screw holding the rotor onto the hub on most models, if it doesn't come off a big *** hammer is needed.
Old Jul 15, 2007 | 08:55 PM
kbunting's Avatar
AudiTech79
Thank you for the reply.
What should the 2 rotor bolts be torqued at (ft lbs ?)and also what is the torque value for the center hub bolt?
Thank you
Kurt
Old Jul 15, 2007 | 09:00 PM
auditech79's Avatar
The big caliper brake bolts have to be torqued to 75ft Lbs.
Which center hub bolt are we talking about? The large drive axle bolt or the little screw that holds in the brake rotor?
Old Jul 15, 2007 | 09:03 PM
kbunting's Avatar
The large bolt in the center of the drive axle on the rear rotor.
Looks pretty much like the same thing on the front and had a flange like a large washer as part of the head.
Kurt
Old Jul 15, 2007 | 09:08 PM
auditech79's Avatar
Oh my bad your talking about the rear rotors, those are simple to get out just remove both of the 13mm bolts using a 15mm wrench or pliers as a counter holder and take off the calipers and knock out the rotors. Those have to be torqued no tighter than 30 ft lbs. As for the center hub bolt you should never have to remove that nut un-less your replacing the axle shaft, that has to be torqued to 150 ft lbs plus a quarter turn with a breaker bar.
Old Jul 15, 2007 | 09:11 PM
kbunting's Avatar
Thank you for the help with this.
I am going to print it out and also save the file on my computer.
I really appreciate the help.
Kurt
KRT_A6_2013
Aug 9, 2015 02:07 PM
NYRangers
Sep 18, 2013 09:38 PM
jchristy27
Dec 26, 2011 05:43 PM
bobthe
Jul 16, 2007 03:59 PM
MPARSONS1
Jun 25, 2005 07:29 AM
