CV Axel replacement
Old Apr 13, 2012 | 02:08 PM
threeputtpar's Avatar
It's a 2003, so the C5 chassis. Remove the lower rear arm's bolt at the bushing, not the ball joint end.
Old Apr 16, 2012 | 01:22 PM
copper07's Avatar
I will get my axle ordered. Thanks for your help
Old Aug 7, 2012 | 09:24 PM
beebopbogo's Avatar
1996 Audi A6 Quatro Wagon, automatic transmission. After replacing the half-shaft, I now have shifting and braking problems.
I had the same issue: torn right/front CV boot. I bought a replacement shaft on-line, but didn't have the tools or space to change it out myself (plus I'm inherently lazy). So I brought it to the shop.
He replaced the half-shaft per my request and also changed out the right/front wheel bearing. He said on the test drive it felt the like that was shot, too. All told, $400 labor/parts plus the half-shaft I bought on-line.
Now my car is having troubles. Rough shifting, going into what I assume is limp mode, ABS warning light illuminated, and the Brake warning light illuminated. Could the shifting issues really be related to the repair?
Here are details if you're interested:
The cause and initial issues: I had a bit too much fun turning around in the dirt parking lot and hit a big pot-hole, "bah-BAM!" Heard some loud grinding, crunching, and clicking mechanical noise from the right front. Upon further investigation from the exterior: torn cv boot. Towed home. When I had time a week later, I drove under 5mph 2 blocks to the shop with new half-shaft in hand. I figured driving on the broken CV joint could only affect the already-broken CV joint and nothing else.
The "fix": At the shop, they said the pinch bolt had at some point been over-tightened (I assume before I bought the car 5 years ago). They also said the wheel bearing would have to be replaced, from the sounds of the test-drive.
After the work was completed, the noise was gone, driving felt good, so it felt like the problem was solved. Except upon the first touch of the brakes, something felt weird.
The brake issue: The ABS was stuttering my braking as if I were skidding, even though I was slowly gliding to a stop from 5mph in the parking lot. After a few second of pressure, the brake pedal would give a little bit and I could continue braking normally. When releasing the brake and reapplying pressure, the ABS would kick in for another 4 seconds or so before relinquishing control back to me again. A bit scary, since the braking wouldn't be as powerful as normal. After driving for about 1 minute, the ABS Warning and Brake Warning lights would illuminate and braking would feel normal again.
Also, after shutting down the car and restarting, this cycle would repeat. 1 minutes of weird braking, followed by the warning lights illuminating and the braking feeling normal again.
The shifting issue: While driving from the shop, I also noticed rough shifting. Not all shifts were smooth, but it seems the roughest were mostly shifting from 3rd to 2nd while braking. While accelerating, no real issues, but once in a while, maybe one in five up-shifts, I would feel a good jerk. That's just during normal driving.
I also noticed a change while gliding down my hill in neutral. I have a good 5 miles of downhill on my commute and tend to skip to neutral. It's the perfect grade for it. Then I would match the revs and slip back into Drive. Smooth. Now, however, it jerks hard enough to feel like I'm going to break something when I slip back into Drive.
And finally, one more weird shifting issue. This only happened twice, but while driving up the long hill the car would not shift from second into third. I released the gas pedal and it didn't shift down like normal. So I sped up to see how far it would go before shifting. I got up to almost red-line before I backed off. It was stuck in 2nd. So I stopped, it shifting into 1st, then I shut down and rebooted-- er, restarted the car. Back to normal shifting. The second time this happened, the car was stuck in 3rd. I tried moving the shift lever from Drive to 3rd, no change (as expected), then slowed down and moved the lever to 2nd. It shifted to 2nd, but even though the resulting rpms were only 3000, the shift was very rough with a large jerk.
Whew! Big post. Sorry, but thanks for the help.
BroBrad21
Oct 21, 2010 03:40 PM
mxjess
Nov 17, 2008 03:50 PM
nitrobrain06
May 8, 2007 11:15 PM
96A4QuattroGuy
Oct 14, 2006 02:21 PM
Bondga
Aug 22, 2006 08:01 PM
