Disconnect the battery?
Old Oct 12, 2008 | 07:12 PM
04A6RGR's Avatar
Default Disconnect the battery?
I am going to be going across the pond soon for a bit and I am thinking of disconnecting my battery while I am gone. Any con's?
Old Oct 13, 2008 | 05:38 PM
ppgoal's Avatar
I have read that the radio may need to be reset with it's security code. You probably want to avoid that unless you have the code already (from the dealer).
I took my A6 off the road this summer in late April and left the battery connected. I admit I have the advantage of starting it twice. You may want to have someone crank it over for you and run it until it's warm. That way the engine is lubed and the battery is charged.
You could also invest in a trickle charger. There are some made to maintain batteries for long periods of time and cost around $50. Google away.
Old Oct 22, 2008 | 11:41 AM
robdance30's Avatar
Just a word of caution for all of you that own a 1999 A6 Q and would like to replace the battery. When you remove the battery you will need to reprogram the computer, so be sure to always maintain power to the computer through the battery cables with a backup battery. There may be another way to do this thru the cigarette lighter but all I had was another battery. The cost to reprogram at the dealer is at least $120 and since the car won't idle and has no power if you fail to maintain power to the computer you probably need to tow it to the dealer.
YorkshireAudiA3
May 20, 2015 08:18 PM
inventorA6
Apr 16, 2010 06:18 PM
iheartboost
Nov 12, 2008 11:02 PM
jandouglass
Jan 2, 2008 05:18 PM
shabbey
Sep 28, 2004 01:23 AM
