Sponsored by:
Sponsored by:
Metal knocking/clinking noise front front suspension, need some help
Old 07-02-2009, 01:23 PM
nitrogen's Avatar
Default Metal knocking/clinking noise front front suspension, need some help
03 Audi A6 2.7T. So here is the story. Had a loud clicking noise when turning a few months ago. I bought new half shafts so that I can repalce the bad CV joints. Last saturday I repalced the half shafts and put on new rotors and pads, no more clicking noise. Now a few days later whenever I hit a very small bump, or the road is uneven I hear a metal knocking noise. Sounds like something is loose but I checked all the bolts and they seem to be tight. Please advise on what the issue might be. I did have to pop out the control arm bushing when replacing the shafts. Also when I hit the brakes even slightly the knocking noise completly stops. Thanks
Old 07-02-2009, 11:49 PM
hxgaser's Avatar
The fact that the noise stops when you apply your brake indicates that the noise maybe related to the brake job. Did you make sure all the hardware are on correctly including the anti rattle spring?
Old 07-03-2009, 12:10 AM
nitrogen's Avatar
Thanks hxgaser. I just took the wheel off and noticed that the calipers on both wheels are a little loose. I don't remember how they were before but after the brake job should the caliper wobble/or move at all on the rotor?. Also I took the brakes apart again and when I was pushing in the piston I noticed that under the middle of the car, right around the tranny some oil squirted out. Is it possible that I have a hole in a hose somewhere and the piston is not holding position properly? any input is much appreciated.
dlokovu
06-28-2015 10:14 AM
U's Audi
08-28-2012 07:27 PM
ONEpointEIGHTtee
10-31-2011 11:10 PM
whitey
04-15-2009 03:03 PM
rocdiggy
02-26-2007 07:51 PM
Quick Reply: Metal knocking/clinking noise front front suspension, need some help
