Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Knocking noise from front end of B6 A4
Old Oct 11, 2011 | 07:58 AM
ONEpointEIGHTtee's Avatar
Default Knocking noise from front end of B6 A4
Ive done a bit of a search already but havent found anything conclusive.
Intermittently over bumps i'll get a sharp "metal-on-metal" sounding knock/clunk noise from the front end. Also hear a similar noise on sharp accel or decel, also intermittently. Usually only hear the noise over a washboard type surface, not big bumps or potholes.
Ive already had the car in the air and done a complete shake down only to find everything is tight as a drum(control arms, tie rods, ball joints, sway bar bushings/endlinks). Also took a dead blow hammer to the tires and different spots on the suspension to see if I could induce the noise...nothing. No clue where this is coming from.
Old Oct 16, 2011 | 09:17 AM
hello?
Old Oct 20, 2011 | 08:26 PM
well this place is no help at all.
Old Oct 29, 2011 | 09:43 AM
yanks51n2's Avatar
check ur strut mounts
Old Oct 31, 2011 | 11:01 PM
ckrummy's Avatar
Sounds like your suspension bolts are loose, they have to stay very tight because the control arm does not pivot during suspension articulation the bushing flex. Jack the car up and do a very good check of all the parts, tighten up all the bolts you can find and use green loc-tite on all the bolts. Also in the future you get more advice when you post in the model specific parts of the forum, fyi
Old Oct 31, 2011 | 11:10 PM
02quattrokev's Avatar
Agree. check your strut mounts and bearings.
dlokovu
Jun 28, 2015 10:14 AM
U's Audi
Aug 28, 2012 07:27 PM
eurostyleb
Jun 19, 2008 01:10 PM
rocdiggy
Feb 26, 2007 07:51 PM
