P0368 Camshaft Sensor
My CEL has been on a few days now and finally had a chance to get to a parts store and hook it up to the OBD reader. Only one code is set: P0368 "The PCM has determined that the voltage signal from the camshaft position sensor "B" is too high for the current engine operating conditions. (Bank 1) (bank #1 identifies the location of the cylinder #1. while bank 2 identifies the cylinders on the opposite bank)
How hard of a replacement job is this? Does anyone have a visual tutorial?
RE: P0368 Camshaft Sensor
first off P0386 is the crank shaft position sensor( CKP )not the cam sensor,
possible faults are insecure sensor/rotor, air gap, wiring, CKP
edit: THEN AGAIN P0368 is the cam sensor ( got to get new glasses )ill take a picture of where they are and you should be able to understand how to change it and not difficult when you take the top cover the timing belt
Here's where it's at on 2.7T. I suspect it's at similar loction on 3.0
Bank 1 CPS shown in figure on thread #78. The bank 1 CPS is 23.
https://www.audiforums.com/forum/aud...8/#post1370249
jkjersey
B7 Models
06-17-2013 09:31 AM
