please help! pulling engine
Old Sep 15, 2010 | 01:38 PM
quattroforthewin's Avatar
Exclamation please help! pulling engine
so im trying to pull out my 2.7 and I would like to be able to do it the way where the transmission comes out with the engine, but, the heat shield that goes over the driveshaft will not come off! I am pretty sure that i am using right torx and it finally just stripped. How can I get these bolts off?!?! what size torx are your guys? and on top of that my heat shield has a huge crack in it. is this ok or should I replace it?
This is the heat shield im talking about...
Old Sep 15, 2010 | 09:31 PM
jhuffman's Avatar
ouch that is going to be a tough one to get out. Once those bolts strip you basically need to either drill it out or give it the vise grips. Depending on which bolt it is (there are three on mine) you might be doing some cutting to get it off and the replacing it.
sleek55044
Apr 24, 2012 03:53 AM
warranty225cpe
Oct 30, 2008 10:53 PM
yesss4
Oct 23, 2008 02:29 AM
b.hasz
Sep 20, 2008 10:06 AM
tank8970
Apr 28, 2006 02:07 PM
