Rough When Turn Off The Engine (2.7)...
Old Jul 14, 2008 | 11:04 PM
omeara7's Avatar
Default Rough When Turn Off The Engine (2.7)...
Is it normal for the 2.7T engine to have a roughturn-off? Mine seems to run for an extra sputteringcycle when i turn it off. Any ideas? Thanks.
-Jon
Old Jul 19, 2008 | 12:01 AM
omeara7's Avatar
Default RE: Rough When Turn Off The Engine (2.7)...
a tiny little nudge...
Old Oct 23, 2008 | 09:52 AM
omeara7's Avatar
Could this be related to bad motor mounts?
Old Oct 23, 2008 | 11:08 AM
nemohm's Avatar
On older engines => combustion chamber deposits, or leaking injectors could be related.
Old Oct 23, 2008 | 05:51 PM
loach1's Avatar
Second that on the carbon in combustion chambers. Try running Seafoam through the top end and see if it improves.
Old Nov 3, 2008 | 10:51 PM
omeara7's Avatar
Thanks guys...I'll try this and see if there's any improvement.
Old Nov 5, 2008 | 10:17 PM
RedShoeRider's Avatar
-Jon
Or it could be sorta normal. My 2.7 does the same thing and has done so since, just about forever ago. I've seafomed it a few times, and, well, it still does it. *shrug*.
I know that's not so helpful, but at least you're not the only one!
Old Nov 14, 2008 | 04:12 PM
omeara7's Avatar
Hmm...did you suck the Seafoam up through a vacuum line? If so, which line did you use? I've heard good and bad things about doing this.
josh A8
Sep 24, 2013 05:45 PM
pschmid
Jun 27, 2008 10:47 AM
viviyer22
Jun 18, 2008 04:31 PM
acollicott
Jan 9, 2008 11:49 PM
the_stig
Jul 4, 2006 08:41 AM
