Steering Wheel won't stay in place
Old Jul 6, 2007 | 12:04 PM
namymark's Avatar
Default Steering Wheel won't stay in place
The steering wheel in my 2000 A6 won't stay in place when I shutdown or start my car. I worked on the stereo a little bit a few weeks ago and since then the steering wheel always retracts when I shut off, then sometimes it moves back to the original position sometimes it doesn't when I start up again. I tried disconnecting the battery to clear the control module but it didn't work. Is reprogramming the control module the only way to fix this problem? Also, can someone please explain why Audi/VW has such horrible electrical engineers, is it a German thing?
Old Jul 6, 2007 | 12:06 PM
techbod's Avatar
Default RE: Steering Wheel won't stay in place
so its an electronic powered steering wheel? have you ever set the modes and stored the memory?
Old Jul 6, 2007 | 02:28 PM
SilverGT's Avatar
I never knew they came power tilt....my car doesnt have it.
Old Jul 7, 2007 | 10:07 AM
reaper's Avatar
Perhaps it wasn't working before and now it is! The power steering wheel is a memory controlled unit along with the seats. It is built and designed to retract out of the way when you shut down the vehicle to facilitate easy entry/exit. When you start the car back up (depending on which key you use) the steering wheel should automatically telescope down and out to the position you have memorized with your seat settings and to your key fob.
Old Jul 7, 2007 | 03:40 PM
namymark's Avatar
reaper, I believe you're right. When I bought my car a year ago it never retracted for entry/exit. However, now it sometimes moves back to position and sometimes it stays retracted when I start the car, there is no consistency. Also I do have the memory seat/steering wheel programmed, which means it should move into position every time.
Old Jul 7, 2007 | 03:43 PM
techbod's Avatar
which means you havnt stored the memeoy of the positions so it will revert back to the standard positions
Old Jul 9, 2007 | 12:25 PM
ppgoal's Avatar
Is this steering wheel memory-thing a standard on all the models, esp asking about my '03? I think mine has a manual adjustment for moving up/down...not retracting. I read the manual pretty thoroughly and never noticed this mentioned.
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
Audi S4 Turbo
Apr 22, 2010 10:42 PM
B5luver
Jun 19, 2007 12:48 AM
AudiTurbo
Mar 1, 2007 01:28 AM
