upper control arms
Old Nov 8, 2009 | 09:00 PM
cardiffkid's Avatar
Default upper control arms
Hi, I'm looking at changing the upper control arms on my 2000 Audi A6 4.2. I've already got the arms , just need to know the best way to go at changing then out. Thanks for any advise Ken
Old Nov 8, 2009 | 11:58 PM
Jackmup's Avatar
Remove the wheel.
Spray the crap out of the bolts with liquid wrench.
Completely remove the bolt from the housing that holds both upper arms in - the arms are notched so it must be completely removed.
Remove the bolts holding them into the upper wheel well and that's that. The front inner bolt may be in back wards so unbolt the strut mount and tilt it out. I cut mine and installed it the other way by persuading the spring out of my way but my bolts were not corroded. If yours are that would be a mistake because you will need to spin the bolt out.
Old Nov 9, 2009 | 06:17 PM
bob martin's Avatar
One other thing: don't tighten the new arms all the way until the car is sitting on the ground.
Bob
jdahlen24
Aug 25, 2011 03:05 PM
shadowboxer
Mar 1, 2009 01:27 PM
awreadie
Jan 4, 2009 05:54 PM
haveaseat
Jun 30, 2007 03:20 PM
duckman
May 17, 2007 02:33 AM
