That weird Transition from 12V to 30V
Old Apr 15, 2006 | 10:00 PM
dan908's Avatar
Default That weird Transition from 12V to 30V
I know very few of you are in this nitch but I don't ever know if I am ok or not... so once and for all:
I have an A6 with the 1997 30V 2.8 (atleast according to all my manuals and the engine cover and all), but when I go to get parts, everything indicates that I have a 12V because the 30V was not offered in the A6 Avant until 99 or any A6 until 1998. I know it is the 1997.5 because I have the 16inch wheels, and I know it is stock and not a replaced engine because I have all the service records.
So my question is, other than the 30 valves is there a difference in parts for the two?
You know, oil filters, Serpentine Belts, timing belts?
I got a timing kit from Shokan for the 12V and it fit and worked fine. THe oil filter always suggests I need an 8994, but I have always had an 8A on it so I get the 8A. But at some point I wonder if I am going to get screwed?
My near future purchases are 4 O2 sensors and the website says on the 97 A6 "12V" it is 4 wire in the front and 3 wire in the back of the cats. But it also says on the 98 30V it is 4 wire all around. Big difference, but, I don't have a 12V or a 98 so I don't get it. *and really it would be a 99 because the 98 Avants were the same as the 97s.
Old Apr 20, 2006 | 02:15 PM
Ootexen's Avatar
Default RE: That weird Transition from 12V to 30V
Think im in a similar boat.... 97 A4 2.8 with 16inch wheels, is there a significant visual difference between the 2 engines to determine which is which?
icetab
May 5, 2013 09:18 PM
ruzoo
May 2, 2011 10:41 PM
flipkid
Jun 4, 2007 12:48 PM
VB05
Nov 27, 2005 01:14 PM
ByPopularDemand
Oct 25, 2005 12:20 AM
