White smoke only at startup?
Old Jun 8, 2015 | 01:42 PM
ppgoal's Avatar
Unless that is something that just started, it is pretty common for water vapor (condensate) to appear when the engine and exhaust are cold, especially on colder mornings. The petrol smell is due to the choke being on. If ithe white vapor disappears after the engine and exhaust warm up, I would not worry about it. You might also notice some droplets of water from the tip of the exhaust pipe for the same reason. As the whole system becomes hot, the vapor is burned off before it becomes noticeable. This is why short trips, which cause water vapor to form and be retained in the exhaust system, leads to said exhaust system rusting from the inside out.
Old Jun 8, 2015 | 01:55 PM
Conrod2's Avatar
I just travelled over 320 miles I know what your saying about the water vapour but this time it more dense and also smells a bit sweet ?
Old Jun 8, 2015 | 02:01 PM
ppgoal's Avatar
I've never had a head gasket leak or cracked block, but my understanding is that when this happens the car blows continuous huge clouds of white "smoke" (vapor). Maybe someone else has some better thoughts.
Old Jun 8, 2015 | 02:10 PM
Conrod2's Avatar
Thanks ppgoal your suggestions have helped
Old Jun 8, 2015 | 06:20 PM
Nebuchadnezzar's Avatar
ppgoal is on the money.
Have a compression test and a leak down test to see what's going on. If the vapor smells sweet, coolant is being introduced into a combustion chamber and being let out through the exhaust values into the tail pipe.
YOSS
Sep 18, 2013 10:49 AM
waltma70
Oct 28, 2010 12:01 AM
esrest
Dec 3, 2008 12:38 PM
