2005 Wheel Offset
Old Mar 28, 2011 | 09:40 PM
Big Diesel A8L's Avatar
Default 2005 Wheel Offset
I have an 05 A8L with the 19" turbine wheels. I want to get the 2011 replica 20" 10 spoke wheels. Spec calls for 35mm offset and the new 20" are a 42mm offset. What do you guys think? Will the 42mm offset work on the 2005 A8L?
You guys know best!
Thanks all.
Old Mar 28, 2011 | 10:13 PM
I'm sorry. I should have given you more info:
I currently have the 255/40/19 turbine wheels.
I want to go with a 255/35/20 that has a 42mm offset and the wheel is 8.5" wide - this is a wheel option on the 2011 A8L.
Old Mar 28, 2011 | 10:53 PM
silverd2's Avatar
I think you have the wrong offset figure for your car. Standard 17" was 43mm....18 & 19" were 45mm from the factory:
http://www.audiworld.com/model/a8/05/05A8.pdf (Page #5...tech specs)
And this 9 spoke 20x9" Audi OEM wheel for D3's: 4E0601025AFZ33 has a 46mm offset:
http://www.ecstuning.com/Search/4E0_...5_AF/ES382856/
43mm should be good on your car...just a few mm's wider stance.
Old Mar 29, 2011 | 09:57 AM
You are bang on!
I spoke with 2 Audi stores this morning and both told me my current offset is 45mm (19" turbine style).
The wheel I want is a 20" with a 42mm offset (China). All the factory A8 wheels are going to 35-37mm offset.
I can buy a full set of Chinese wheels for the price of one factory 20" Audi wheel.
Thanks for your input!
Old Mar 29, 2011 | 10:10 AM
silverd2's Avatar
Just a note: In normal/light usage, it shouldn't matter...but you will be accepting a large drop in quality to save that $$...many buy refurbished Audi OEM's instead.
The cheapest alloy wheels are usually "gravity cast" ...simply poured into a mold.
Better wheels are either "pressure cast" or "high pressure cast" ...much stronger.
The best wheels are "forged", which are cut/formed from billet ...the best quality available.
Most Audi OEM are forged (even 17" fat-fives) or at least HP Cast.
In the most extreme conditions (example: combo of extreme cold and hitting pot holes), cheaper construction are more prone to breakage and warping. I personally have had pretty good luck with pressure cast in the past, at reasonable prices. Forged are the best, but never cheap.
P.S. The change in offset lately "could" be a change in body/suspension configuration in the newest models...not sure, though(?)
Zigz07
B7 Models
10
Jan 4, 2011 06:19 PM
onepoint8tee
Sep 22, 2008 05:23 PM
audiRSallroad
Jul 6, 2008 01:49 AM
02A4Turbo
Feb 6, 2008 01:04 AM
wildcatknh
Jul 11, 2006 06:23 PM
