Catalac converter .... remove!?
Old Dec 5, 2006 | 10:25 PM
XCLR8TT's Avatar
Default RE: Catalac converter .... remove!?
ORIGINAL: achTTung
ha. you've done it, and didn't remember, I have no reason to do it, and its the first thing to come to mind.
Senior moment[&:].. besides take a look at my Mods list... It's hard to keep track after awhile without looking at the cheat sheet.
Old Dec 5, 2006 | 10:46 PM
foxrcng11's Avatar
just run a cheater pipe along side it or for a few bucks you can get something that will cheat the sensor into thinking its fine
Old Dec 6, 2006 | 07:12 PM
racer_x's Avatar
ORIGINAL: quaTTro225
i dont think you would really gain any horsepower, but i would def sound nice
With a N/A motor you'd be closer to right, because a normally aspirated motor usually requires some kind of backpressure to generate torque.
However, a turbo motor should, ideally, run an open downpipe! The faster you can get the exhaust out of the pipe, the faster the turbo can spool harder. Actually, bmwtoaudi, find my post about an electronically-actuated exhaust diverter valve or cutout. I am installing one of these VERY soon; I can't wait! What I want is something that will go from stock sounding to NOT stock sounding at the push of a button, without changing the computer's readings of what's happening in the exhaust.
*EDIT* I forgot to mention... It's really going to add some grunt, too-- low, mid and high range.
Which brings me to point B: 02 sensor dummies. AchTTung's right again, you must locate a dummy to send a signal to the cats that everything is A-OK. If the reading is good all the time, the car will not be the wiser.
Check out my post for plenty of info on the subject... hope this helps! If I beat you to it, you had better believe I'm going to be posting some in-car footage (narrated by Leonard Nimoy ((or me, depending on who's available))) and out-of-car soundtrack.
I'll keep everyone posted....
Old Dec 6, 2006 | 07:16 PM
techbod's Avatar
so would you fit both spark plug arrestors in the O2 sensors or just one and where
Old Dec 6, 2006 | 07:20 PM
techbod's Avatar
ORIGINAL: racer_x
swine this is an old post
Old Dec 6, 2006 | 07:25 PM
XCLR8TT's Avatar
ORIGINAL: avant80@2.6
Just on the Post-Cat sensor. The pre-cat sensor is responsible for engine management (i.e. air-fuel, etc.) the post-cat is there to check catalytic converter efficiency for emissions and is the one that benefits from the removal from the direct exhaust flow.
Old Dec 6, 2006 | 07:26 PM
racer_x's Avatar
Yes, +1
Old Dec 6, 2006 | 09:50 PM
  #18
eliTTe's Avatar
so there is no way to get rid of the code with a VAG-COM?
Old Dec 6, 2006 | 11:13 PM
  #19
XCLR8TT's Avatar
ORIGINAL: eliTTe
You can clear the CEL, but it will keep coming back unless you change the signal or modify the sensor location
liquidcool
Aug 30, 2011 08:39 PM
kevace1
Mar 11, 2010 12:23 AM
mrbloink
Jan 10, 2009 10:29 AM
austina3
Jan 8, 2008 10:05 PM
TakingBackSomeday
Jul 1, 2007 09:41 PM
