Losing boost in 2nd gear?
Old Jul 5, 2007 | 06:26 PM
foxrcng11's Avatar
Default Losing boost in 2nd gear?
should that be happening? When I get to higher rpm in 2nd gear id say past 4k i lose boost. The car is completly stock. Any thoughts? its an 01 180q
Old Jul 5, 2007 | 06:31 PM
Murderface's Avatar
Default RE: Losing boost in 2nd gear?
Gimme some numbers...theK03s tends to spike then drop off towards higher RPMs. How bad are you losing boost? I.E. what's it dropping to?
Old Jul 5, 2007 | 06:49 PM
cincyTT's Avatar
I'm make believe
you have to deal with load and the small turbo (cant hold boost very well). If you increase the boost you will have more psi throughout the powerband.
Old Jul 5, 2007 | 07:36 PM
foxrcng11's Avatar
goes from 15ish to 5 if i go to redline
Old Jul 5, 2007 | 07:54 PM
cincyTT's Avatar
I'm make believe
thats normal. chip and mbc will take care of that problem.
Old Jul 6, 2007 | 01:25 AM
foxrcng11's Avatar
really? never seemed like it did it before unless i never paid attention to it. just seems like it shouldnt do that lol.... im a noob to turbos but how would an mbc fix it? isnt something like that computer controlled on our cars?
Old Jul 6, 2007 | 02:02 AM
225tt's Avatar
Once you get a chip and mbc, it will go from 22(lets say) to 15 that will be your new normal. I wish it would just hold 22 thru the whole powerband, that would be nice!
Old Jul 6, 2007 | 01:26 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: foxrcng11
a mbc would allow the turbo to spool up faster by keeping the wastegate closed longer and then it will hold the boost longer by bleeding off the boost slower. Not computer controlled, just a simple controller you insert before the wastegate in the vacuum line.
Old Jul 6, 2007 | 03:22 PM
foxrcng11's Avatar
ahhhhhhhhhhhhhhhhhhhh now it makes sense thnx!
gold01A4
Apr 18, 2013 09:05 PM
ChrisW92410
Nov 17, 2011 05:52 PM
ADubyaD
Apr 17, 2007 10:22 PM
itsquattro
Dec 12, 2006 09:47 PM
thizzwatitiz
May 15, 2006 12:19 AM
